Microwave not heating and shuts downs immediately
Brand: DeLonghi
Model Number:D90D25ESLRIII-ZWB
Main Symptom: NOT HEATING
What happens & when: it turns on but when the button is pressed for microwave it stops immediately. Also the it all started when it blew during a thunder strike when in use. It affected the board.
Error Code (if any): None
Parts or tests already tried: Capacitor, Diode and transformer. Also change the AL Cap
It would be recommended to test the door switches to make sure that they are good. This would be the most likely cause for this issue.
Thank you, so much for this feedback, I think the door switches are working cos they are clicking. I may need to test them with a multimeter then. The bulb comes on when the microwave is open and goes off when the door is shut. Although was started the issue was that it burnt cos there was a thunder strike when it was used.
