Microwave Light
Need some detail on how to install replacement light bulb in microwave oven
Roes,
I take for granted, you mean the oven cavity light, not the cooktop lights.
Here is the part number and the instructions from the service manual.
Good Luck,
AP6009659
[LEFT]Grille
The top full-width grille is removable for service to some
components, such as: humidity sensor, oven light, door
removal, flame sensor, vent motor capacitor, fuse,
control panel, and stirrer motor (some models).
Grille Removal
[FONT=Helvetica][SIZE=2][COLOR=#231f20][FONT=Helvetica][SIZE=2][COLOR=#231f20]1. Disconnect power to oven.
2. Remove screws located in front on top of microwave[/LEFT]
securing grille
[LEFT][SIZE=2][FONT=Helvetica][COLOR=#231f20][FONT=Helvetica][SIZE=2][COLOR=#231f20][FONT=Helvetica][SIZE=2][COLOR=#231f20]3. Pull outward on the top portion of the grille releasing
the tabs.[/LEFT]
4. Reassemble in reverse order.
[LEFT]Light Socket
2. Remove Grille (see “Grille” procedure).
3. Remove screws securing bulb holder.
4. Remove light bulb and socket.
5. Disconnect wire terminal plug.[/LEFT]
6. Replace and reassemble in reverse order
[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/FONT][/SIZE][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT]
