Microwave LED display
Brand: GE
Model Number: JNM3163RJSS
Main Symptom: LED display
What happens & when: The LED display is flashy like it isn’t displaying correctly (9 looks like a 5) - is there a fix or replacement part?
This is going to be a control board failure. However, there should be a number in between the J and the S at the end. This number would be needed to identify the correct part number.
The full model # is JNM3163RJ5SS
Here is the control that would be used with your model. WB27X29801 Control Board | Genuine Ge OEM In Stock
