I have an older GE microwave that keeps blowing its line fuse. When I bypass the fuse (with a screwdriver) the unit seems to run fine (I only test this for a few seconds). Is this repairable, or should I buy a new one? When I have tried using the model # on parts websites, they don’t recognize the #. Maybe its just too old (?)
[QUOTE=marco polo;800145]I have an older GE microwave that keeps blowing its line fuse. When I bypass the fuse (with a screwdriver) the unit seems to run fine (I only test this for a few seconds). Is this repairable, or should I buy a new one? When I have tried using the model # on parts websites, they don’t recognize the #. Maybe its just too old (?)[/QUOTE]
Marco, It,s most likely a faulty door switch or possibly a wiring issue. But we were unable to research your parts or service information, either, we used the GE manufacturer’s web sights. You may want to consider a replacement.
Thanks. I Appreciate For Your Attention To This. Marco
Marco,
We appreciate you. We just wish we could get you some applicable information and parts, so we could get you up and running.
Thanks,
