[FONT=Arial]Hello, I had a business some years ago, I worked on microwave ovens. I have run in to a few senior moments. I have a GE above stove microwave oven only 4 years old, every thing about the cabinet works good, lights, stove fan works good. The problem I’m having is some times when I use the microwave oven the unit comes on and it scrambles the clock and turns off. I have tested the diode for leakage and found none, tested the BIG cap and it’s good.[/FONT]
[FONT=Arial]I remember in some of the older units the PC board had a Cap Battery for the processer memory, when there was a moment of high current the Cap Battery would hold the memory and the clock.[/FONT]
[FONT=Arial]If this is the case on this board, can someone point me in the direction of that Cap and or part number… The biggest Cap on the board is 470uF@35Volts, Please let me know if I’m looking in the right place. I don’t have a small cap tester, just for the big caps.[/FONT]
[FONT=Arial]Thank you for your time.[/FONT]
[FONT=Arial]TSlaten007[/FONT]
