Microwave handle broke off
my microwave handle has cracked off. i am waiting for the replacement handle and want to be ready to fix once i get it. i have looked at the door and cant find any screws to remove to see what has to be done. when it cracked off there is plastic still inside two holes. how do i get behind to remove and re-install the new door?? thanks
[FONT=Times New Roman][SIZE=3][COLOR=#000000]This page should help GE Spacesaver Microwave Handle Replacement[/COLOR][/SIZE][/FONT]
[SIZE=3][COLOR=#000000][FONT=Times New Roman] [/FONT][/COLOR][/SIZE]
[FONT=Times New Roman][SIZE=3][COLOR=#000000]Once you access the screws you can hold the plastic with needle nose pliers and turn the screw out. [/COLOR][/SIZE][/FONT]
[QUOTE=applianceman;157374][FONT=Times New Roman][SIZE=3][COLOR=#000000]This page should help GE Spacesaver Microwave Handle Replacement[/COLOR][/SIZE][/FONT]
[FONT=Times New Roman][SIZE=3][COLOR=#000000]Once you access the screws you can hold the plastic with needle nose pliers and turn the screw out. [/COLOR][/SIZE][/FONT][/QUOTE]
My handle broke at the top and bottom clips that holds it into the door. I can not see the screws but think the page posted will help. My question is, will the new handle come with the clips that need to be replaced in the door or do I need to order another part?
