microwave door hinges loose -frigidaire
The hinges on my microwave door are loose - where it connects to the oven (they are secure in the door). It appears that a screws should hold each hinge to the oven - but i cannot find this on any diagram of the oven - so not sure if a) the hinge is secured by screws or something else; b) if so, what size screw; and c) is it installed from the inside or out?
How did you repair the door hinge?
