Microwave damper clicking with no display
Brand:GE
Model Number:ZSC1001KSS01
Main Symptom: no display
What happens & when: clicking when plugged in
Error Code (if any): none
Parts or tests already tried: replaced display board
A lot of times this is the power transformer AP3883205 which has been discontinued by the manufacturer and is no longer available for purchase, but it can also be nearly any of the control boards in that area. Unfortunately, there isn’t a way to test which is bad other than replacing each board in turn.
https://www.appliancepartspros.com/ge-transformer-power-wb17x10021-ap3883205.html
The other boards that could be part of the problem are on the page below:
https://www.appliancepartspros.com/control-parts-for-ge-zsc1001kss01.html
