I have combo oven/micro built-in. The interior light for the micro is burned out…how do I get to it for replacement. There is no cover panel on the interior to access the bulb and according to your parts diagram, I think it has a lens cover that prevents me from getting to the bulb from the microwave interior…thanks for your help. I’m pretty mechanical as I recently replaced the oven latch assembly for this same unit…thanks again
hello! i have the same combo and i was wondering if i could get a diagram for replacing the bulb in the microwave. do you have a manual that shows the light bulb or tells you ow to replace it? thank you.![]()
Rozman, you said you have the same combo as Cityservices, but then you put GE light bulb replacement as your subject so I want to make sure we are getting you the right information. Starting a new thread with a model number would be a great help to get you going in the right direction.
