Microwave 3 door switch configuration
Brand: Kenmore
Model Number:790.80353310
Main Symptom: Uncontrolled start
What happens & when: When door is slightly opened (sli9ght uplifting), light, fan turn on, not the turntable.
No error code. Error Code (if any):
Parts or tests already tried: Tried door switch configuration: Top NO, Middle NC, Bottom NO. What is the correct door switch configuration
The configuration that you listed would be correct for the switches on this unit. Check the latch to make sure that it is good.
