Micro wave bulb replacement
Trying to figure out how to replace the bulb in the upper microwave without totally removing the entire soluble oven out of the wall.
If it is installed like mine is in the wall cabinetry with stainless (or other)molding around it to frame it in, you will have to remove the molding - just unscrew them and then remove the microwave - looks like any regular countertop microwave and put it on a surface where you can then remove the top off of it - again more screws. It’s really not that difficult, just time! I know it sucks and I have had to psych myself up each time I’ve had to work on it (I’ve replaced the magnetron twice - and a fuse). Truth be told, I wish I would have replaced the bulb the last time I got it out too! If you have a teen handy, have them help you fetch it from the wall to surface. Good luck!
