Med No Heat
Rca Dryer Turn Control Knob To Hot Heat Everything Is Fine, When Turned To Medium Setting No Heat Any Ideas?
The first thing I would check for continuity is the cycling thermostat (#275 on the cabinet break down diagram) with lower temperature (the temperature is written on the thermostat) .
If it’s open - it has to be replaced.
If it’s closed then the timer is the second failure suspect.
Here are the break down diagrams for the RCA (GE) dryer Model DRB4400SBLWW
