My Maytag dishwasher won’t stop running. It acts like it is going to stop, then continues rinsing or washing. I am not sure. What is this and how can I fix it? Thanks! I have a kid with a pretty serious medical issue so any help would be appreciated. Thanks
Replacement parts for MDB5601 models | AppliancePartsPros.com
Here is a tech sheet
http://www.servicematters.com/docs/wiring/TechSheets_11_17_09/Schematic%20-%20W10179503.pdf
Could be the unit is waiting for the water to heat to the required temperature.
Try a Rinse Only cycle if that completes then the above is likely.
Check the heater itself should be about 15 ohms, it’s thermostat should be 0 ohms and the thermistor should be around 10,000 ohms.
You should call Maytag at 1-800-344-1274 to check for recall or anything.
