Dryer won’t turn. The timer works and the light turns on when I open the door. I hear the “click” when I push start which activates the timer but it won’t turn. Could this be a bad door switch? Thanks in Advance!
Replacement parts for Maytag MED5870TW0 29" ELECTRIC DRYER | AppliancePartsPros.com
See the attachment for the wiring diagram
You said “The timer works”.
If by this you mean that the timer advances when in a timed dry mode then the door switch is OK.
There seems to be a disagreement between the wiring diagram and the parts breakdown.
The wiring diagram shows a thermal fuse in the motor circuit but I cannot find it in the parts.
If it has one then it will be mounted on the blower.
It will be like the following.
AP6008325
Click on the picture for more info.
I would check for this first.
If it has one and it is blown then be sure to check/clean your vent system as this is the most common cause of it blowing.
MED5870.pdf (186.3 KB)
