My dryer is not heating. Where should I start?
Hi.
First check if you are getting 240VAC to the dryer.
For the next tests we need the serial number.
Simon.
Serial #12486909EA
I’ll have my husband check it. He has a meter. Although nothing has changed as far as power supply, nonetheless - we’ll do step one.
We are getting 240VAC to the dryer. What’s next?
Hi.
Get access to the heater and check if there is 240VAC at the heating element. If yes - replace the heater AP6024199
If not - check the continuity of the fuse 40113801
and the hi-limit AP6015206
If any of them is blown you need to clean the air ducts inside and outside the dryer.
Here are the breakdown diagrams and Replacement parts for Maytag SDE2606AYW DRYER- ELE | AppliancePartsPros.com
Simon.
