When I close door for my dish washer 3 led are flashing Clean-Heavy wash and Heated dry. What kind problem is that:confused:
Replacement parts for Maytag MDB7100AWW DISHWASHER- UNDERCOUNTER | AppliancePartsPros.com
Probably something to do with the control board or the control panel.
Have you tried unplugging or flipping the breaker off for a couple minutes?
Take a look for the tech sheet, under the unit or it may be taped to the back of the kick plate.
I cannot find a tech sheet for this unit on-line.
The tech sheet will have info on what many flashing light errors mean.
