I’m having some intermittent problems with the dryer. I took off the panel and the igniter starts the gas sometimes but not all the time. Then when i check the laundry the cloths are still damp and the flame is out. So I don’t get full heat to finish a full load of cloths. What do you thing is the problem? Relay?
Any help will greatly appreciated.![]()
It sounds like your coils may be bad. Check the coils and see if they test good. You can test the coils using a multi-meter. The two prong coil will read 1,000-1,300 ohms, and the three prong coil will read 1,300-1,400 ohms across prongs 1&2, and 500-600 ohms across prongs 1&3. Hope this helps.
AP3094251
Gas valve & igniter replacement parts for MAYTAG SDG5701AWW DRYER- GAS | AppliancePartsPros.com
