our dishwasher will fill with water and do nothing else. The timer counts down, but nothing happens after filling. It will not drain. We have just replaced the contorl board (today) afteer findin a couple of burnt resistors on the old board. The board does make a click sound every so often. Any help would be greatly appreciated. AppliancePartsPros say the board cannot be returned. Thanks
Here are your parts includes a wiring diagram.
Replacement parts for MAYTAG MDBD880AWB | AppliancePartsPros.com
You may want to check out the following
http://www.servicematters.com/maytag_library/docs/TDD-0011B-B.pdf
Sounds like the motor is not getting power or is shot.
I would disconnect it and check that the windings have continuity.
Note: This unit may be part of a recall
After reading your Tech Bulletin, where do I find the date code? I will check the motor as well. Thank you for your quick reply.
Date codes
http://www.servicematters.com/maytag_library/docs/P-0004-B.pdf
May be best to just call Maytag if the rinse aid has been leaking.
