Maytag Water Valve Replacement
Hi, new to the forum. I need to replace a water valve, on Maytag Washer Model#LAT9306AAE. The MFG replacement for the valve is 22001274.
It has been a while since I took the old one out, and I can’t find my notes as to the two plug-in, that connect to the hot water solenoid, and the cold water solenoid.
I know the plug with the blue & white wires go to the cold
and the orange and white go to the hot, what I don’t know is which terminal does the blue, and likewise for the orange, since they plug can be turned and connected two different ways.
Thanks for any help
Actually it doesn’t really matter. As long as you hook your hot water source hose to the valve that has the orange/white wires and the cold water one to the other connector you will be fine. If for some reason you reverse things and get a hot water rinse just reverse the connections of the hoses at the valves.
