Brand: Maytag
Model Number: MTW577OTQO
Main Symptom: stops in cycle/trips breaker
What happens & when: changed out timer August 2025, now the machine trips the breaker at times or stops mid cycle and not emptying the machine. was making a humming noise also.
Error Code (if any): none
Parts or tests already tried: changed timer August 2025, rechecked connections.
Check to make sure that there is no issue with the wiring and that there are no pinched or damaged wires. It would also be recommended to make sure that the motor is not locking up causing this issue.
I checked the connections and the wires aren’t crimped or loose. It was agitating and spinning. I was just having to manually advance the dial thru the cycles/ the dial isn’t advancing itself thru the cycles. The breaker tripping started after replacing the timer in August.
Re-commenting because it has been a week with no response.
With the wires being good then this would be a suspected timer that would be the issue.
