Maytag washing machine
Trying to check where odors are coming from when the washer is running! I’m not sure if the pump is pumping all the water out? and the stench is coming from the water that is left. Should the pump run all of the water out of the tub?
Also I noticed when I had the level in the mini setting the washer still filled 3/4 of the way full. Whats up with that?
As far as I can see Joe replied on your first thread: http://forum.appliancepartspros.com/washer-repair/152981-bad-odors.html but you did not answer his questions yet.
Affresh works very good with all kind of washers, does not matter front loading or top loading.
Thanks for the reply! Do you Know anything about the level “sensor”?
