I have a maytag washer that continually drain besides the cure of bringing the hose up higher is there a part that needs to be replaced:cool: thanks for imput
SK,
It,s not likely you’ll need additional parts for your drain problem.
The first thing you need to do is get the proper heigth on the drain pipe,
** top of pipe needs to be 36 inches high from floor level to top of drain pipe. **
The lower the pipe heigth the more problems you’ll have with a “syphonning effect”.
You need to take care of that first, it’s probably the whole problem as well.
