Maytag Washer
The washer does not drain and stops after the rinse cycle. Not sure if it is the timer or the pump. I tried to advance the cycle, but it still does not drain. I am also looking for a repair manual for this washer and can not find one, Any suggestions. I also need top know how to disconnect the front cycle knob from the control panel so I can disconnect the timer. Thanks
Anita
See if this is the manual for your machine.
http://www.servicematters.com/maytag_library/docs/16010373%20(16001145).pdf
Yes , it seems to be the manual. Thank you…where did you find it? I looked all over for it.
Thanks again.
Anita
Good, glad that works. Sometimes these are available from Maytag
