My top loading washer wouldn’t spin out the water and now it won’t even agitate. Any help would be appreciated. Is there a belt somewhere?
Model MAV208DAWW
Here is a service manual, wiring diagram ans some tech sheets which may be relevant
http://www.servicematters.com/maytag_library/docs/16026502.pdf
http://www.servicematters.com/maytag_library/docs/16027498.pdf
http://www.servicematters.com/maytag_library/docs/TDL-0143-B.pdf
http://www.servicematters.com/maytag_library/docs/TDL-0113-S.pdf
Thank You so much. I appreciate it. Now I will see if I can track down what the problem may be.
