I think the timer might need to be replaced in my Maytag washer (SAV365ZAWW) but I wanted to describe the problem here to perhaps get some confirmation.
The washer will not switch from agitating to the spin/rinse cycle on it’s own. The knob will turn/advance as it is supposed to, but it just keeps agitating. I can push in and pull out the knob when it’s in the correct position to spin and it will then spin, drain and refill and start agitating again, but it won’t shift to spin by itself.
If I leave it alone it will agitate through all the cycles and then beep to let me know it’s done but the clothes are still sitting in soapy water. I have to then turn the knob around to the spin position.
Normally I’ve been trying to set a timer for each cycle so I can stay on top of the laundry and not forget about it.
One other thing I wanted to mention - some times when I put the knob where I think it should be (there is no specific marking for that first spin cycle) and pull it out, it seems to have landed in an in-between spot where it tries to shift to spin on it’s own. If I let it sit there it seems to short out the whole machine and I have to unplug the washer for 5 minutes to get it to work again.
So now when I realize I’ve hit that spot, I push the knob back in, turn just slightly further, pull it out and it starts to spin.
I think I’ve described everything pretty accurately but please let me know if any clarification is needed.
Thank you!
Rene’
