Maytag washer stops filling
i have a maytag washer that starts to fill with cold water, at first i have good water flow then just a trickle . if i push in the knob and then pull it out i get a good flow of cold water but only for a few seconds. i changed the fill valve solenoid to no avail.
A model number will help us to help you.
i am sorry i dont have the model # with me right now, i do however have the part # of the valve that i replaced , it is WPL 8578340. i can provide the model # of the washer later today
the model # of the washer is MTW5570tq0. Thanks for any help you can provide
What you describe sounds like a timer problem.
AP6015122
mine too it starts to fill than stops after 15 seconds. I think the water level switch is o.k.,timer is o.k. also:confused:
kenmore 400 tl modle #11029442800
Richie: Please post this as a new topic and give us a complete descripion of the symptoms, and what you’ve checked. thank you.
