Maytag washer stopped mid cycle
My front load Maytag washer has stopped mid cycle and won’t re-start. It’s happened a couple of times in the past, but I’ve always been able to re-start it. This time, it just sits there. I’ve tried unplugging it, I’ve tried it on different cycles, you name it, but no luck If you leave it, it will just come up with some error message. Anyone have any ideas?
Parts for Maytag MHWZ400TQ02 Washer - AppliancePartsPros.com
See the attachment for the tech sheet which should help you troubleshoot this.
PS: You are in the wrong section re: Dishwashers.
MHWZ400.pdf (478.6 KB)
