Maytag washer skipping wash cycle
Brand:Maytag
Model Number:MVW7232HCO
Main Symptom:b skips wash cycle
What happens & when: washer door locks, senses, spins, does not wash, and says wash is complete
Error Code (if any): F7E4
Parts or tests already tried: replaced slider (W10734521), replaced main control (W11417463)
From what I can find, the main control needed with this model is different from what was installed. This could cause the cycles to skip through improperly. The error F7E4 indicates the main control is sensing that the shifter is not engaging or disengaging properly which could be a main control or a shifter failure. The clutch can be checked to see if it is able to lift and descend properly. If it can, there is a voltage test that can be done to identify if the shifter will work properly or not. Here is a link to the control that is recommended by the manufacturer. W11419171 Electronic Control Board | Genuine Whirlpool OEM In Stock
