Neil2
1
Brand: Maytag
Model Number: MVWB835DW3
Main Symptom: Not completely draining and does not start spin cycle
Error Code (if any): No error code given
Parts or tests already tried: Unplug and plug back in then switch to Rinse & Spin works.
Is this happening during every wash cycle, or only with one specific cycle?
Neil2
3
Thank you for responding.
Yes, this seems to happen with every wash regardless of what type of wash cycle we choose. The lid is locked with the lid lock light on.
I will unplug the machine, wait a few minutes, plug it back in and switch to the Rinse and Spin cycle to finish the load.
If you quickly press temperature, soil level, and spin speed in that pattern 3 times, does an error code appear? If not, the main control would be the likely cause of failure. W11400681 Electronic Control Board | Genuine Whirlpool OEM In Stock
Neil2
5
Thank you for the response.
Should I try this procedure during a wash cycle when the machine stops operating?
This would be done when the washer is in standby. There would not be any need to put it into a cycle at all.
