Maytag Washer MVWC565FW2
Brand:Maytag
Model Number:MVWC565FW2
Main Symptom:Plug unit in drain starts running and doesn’t stop. No lights showing
This issue started at the end of the prior wash cycle, The drain keeps running and no lights. Unplugged over night. When plugged back the drain started running and still no lights showing. I held in the cancel button for a minute and the unit still runs
You will want to check to make sure that the pressure hose is not clogged. You could also try to remove the hose to see if the unit stops the drain from running. This issue will most likely be an issue with the control board.
Thanks for responding, Is the pressure hose the clear tube ? And if it is the control board will I have to replace the board or can it be repaired.
Again
The pressure hose is the clear tube attached to the control board. If the control board is faulty it would need to be replaced. W11654022 Electronic Control Board (Main) | Genuine Whirlpool OEM In Stock
