Maytag washer MVWC565FW1
Brand: Maytag
Model Number: MVWC565FW1
Main Symptom: grinding noise when spinning or agitating and stops during spin or sensing cycles
Parts or tests already tried: I have replaced the transmission from you guys. Within the first wash I noticed loud grinding noises anytime the drum or agitator moves. Within the first week I changed the shift actuator and I noticed there was a lot of grease on the housing where the best is. I am able to move the drum freely but it makes a clicking noise and can hear soft grinding noises. There are no plastic chips in the washer or under. The washer is not been able to go past a sensing cycle nor can I get it to complete a fully calibration. No error codes ant shown but the sensing or spin light flashes when the washer stop in that cycle
Photos / video link:u
Since the grinding noise started immediately after replacing the transmission (gearcase), and you’re now seeing grease around the belt housing, I would be concerned about either a defective replacement gearcase or an issue with the drive pulley and splutch assembly.
The washer stopping during sensing, spin, and calibration could be caused by excessive resistance in the drive system or the control not detecting proper basket movement.
I would avoid running any more wash cycles until we determine where the grinding noise and grease are coming from.
Here is what I would check next:
1. Transmission (Whirlpool W11454734 Washer Transmission Gearcase | Genuine OEM Part) leak – Unplug the washer, drain any remaining water, and safely access the underside. Remove the belt cover and inspect the bottom of the new transmission around the pulley shaft. Look for fresh oil or grease leaking from the shaft seal. Excessive lubricant is not normal.
2. **Splutch assembly (Whirlpool W10721967 Washer Splutch Pulley And Cam Kit | Genuine OEM Part) ** – Remove the belt and inspect the plastic cam, spring, and drive pulley for worn teeth, improper installation, or binding. Make sure the pulley nut is tight and the pulley isn’t rubbing against the belt cover.
3. **Shift actuator (Whirlpool W10913953 Washer Shift Actuator | Genuine OEM Part) ** – Verify that the actuator arm is properly engaged with the splutch cam and that the wiring connection is secure.
4. **Transmission and motor (Whirlpool W11026785 Washer Drive Motor | Genuine OEM Part) ** – With the belt removed, rotate the transmission pulley and motor pulley separately by hand. Neither should produce a harsh grinding noise. This should help isolate where the noise is coming from.
5. **Basket drive hub (Whirlpool W10528947 Washer Drive Hub Kit | Genuine OEM Part) ** – Remove the agitator and inspect the hub for worn or stripped splines. A worn hub can cause grinding and prevent the washer from reaching the proper spin speed.
6. Stored error codes – Enter diagnostic mode and check for stored fault codes, particularly F7E1 (basket speed fault) and F7E5 (shifter fault). Codes may be stored even if none are displayed during normal operation.
Maytag+2
My biggest concern is the grease buildup. If the replacement transmission is leaking, it could contaminate the belt, cause slipping, and interfere with sensing, spinning, and calibration.
Could you provide a few pictures of the grease buildup, the bottom of the transmission, and the splutch assembly? Also, did you reuse the original splutch assembly and drive belt when you replaced the transmission?
If we can confirm that the new transmission is leaking or grinding internally, I would recommend contacting our customer service department about a warranty replacement before purchasing any additional parts.
