Maytag Washer Makes Loud Moaning Noise During Spin Cycle.
[SIZE=3][COLOR=#000000][FONT=Times New Roman]On this model the spin bearing normally causes this. Most of the time the tub seal is leaking causing the spin bearing to go rust and be noisy. To confirm remove the front start the washer and watch for leaks where the transmission enters the tub. note that sometimes it will be a small leak that you wouldn’t notice maybe one or two drops a load. [/FONT][/COLOR][/SIZE]
[FONT=Times New Roman][SIZE=3][COLOR=#000000][/COLOR][/SIZE][/FONT]
[FONT=Times New Roman][SIZE=3][COLOR=#000000]Note that if you don’t see a leak it can also be the bearings in the pulley under the bottom or the pump. [/COLOR][/SIZE][/FONT]
[SIZE=3][COLOR=#000000][FONT=Times New Roman][/FONT][/COLOR][/SIZE]
[SIZE=3][COLOR=#000000][FONT=Times New Roman]Clothes Washer Repair Guide[/FONT][/COLOR][/SIZE]
