Maytag washer growling
Brand:Maytag
Model Number: MVWX600XW2
Main Symptom: noisy
What happens & when: growling noise while it spins, even by hand.
Error Code (if any): none
This is likely a bearing issue, and the bearings for your model are a part of the gearcase assembly.
https://www.appliancepartspros.com/whirlpool-gearcase-w11454372-ap6993914.html
https://www.appliancepartspros.com/repair-help/washer-repair-help
Thanks, that’s the part I guessed, so I ordered it. I was hoping for confirmation. Now I feel better about it. Now I can sleep tonight.
Good luck with it, lets us know if we can help!
I replaced the gear case assembly, clutch, and belt. It immediately started making some other noise and smells like something burning. Any ideas?
Re-check the drive pulley, splutch, and the belt guard/shield for something rubbing. Ensure all these pieces are fully in place and not loose.
