Brand: Maytag Model Number: MVWB835DW3 Main Symptom: Will not wash. What happens & when: Washer locks, starts to “sense”, then goes to “wash”. No water fills, goes back to “sense” then will go to completed cycle and the lid takes extra time to unlock.
Error Code (if any): F7 E5
Brake & Clutch Assembly (AP5952873) or the Washer Transmission (AP6977680) is what parts come up as possible to replace. I don’t want to but the transmission if its the wrong part to replace.
Ok, verify if the tub is moving when it senses. I’m attaching the tech sheet for this model below. Use the tech sheet to go into diagnostic mode and go to the load test described on page 4.
Lock the lid on test 0 or 000. Then go to test 10 and start it. Watch to see if the tub is spinning or just the agitator is spinning.
If just the agitator is spinning then the clutch isn’t engaging the slider to engage the spin basket. This could be a bad clutch, bad slider, failed control board, or the gearcase.
Let me know what you find when running test 10. If it seems to be doing what it should then run test 51 to verify everything is acting properly in that test cycle.
