Maytag washer code 2/3
Brand:maytag
Model Number:
Main Symptom: code 2/3 mismatched acu/ui
What happens & when: code2/3 Replaced control board no electricity an no green light. Ran AI test, won’t go past putting water in. Had code 9/1 long drain fault. Had electric to the pump. Replaced pump. Now have code 2/3.
Hello, if you can provide me with a valid model number, I will try and assist you.
Sorry just figuring this board out. I sure thought model number in. But here ya go .MVW6200KW1. thanks!!
I see an F3E2 error code, that is a pressure system fault, I do not see a F2E3 error code. make sure the pressure hose is not pinched or disconnected.
Hope you can see. Thdnks!!
That looks like maybe an UI and control mismatch? Double-check the part to make sure it is the right part for your model. That error code does not come up on the tech sheet for the model I have.
| Maytag Washer W11491435 Main Control Board MVW6200KW1 | |
sj-W11491435. Think it’s right
Other than checking the connections, I can’t think of anything else to tell you.
I appreciate it!t Thanks!!
