Maytag Touch pad not working
The touch pad is not working on my Maytag dishwasher. The unit is less than 3 years old. I thought the problem was the control board so I replaced it. This did not solve the problem. The touch pad still is not working. Is the problem the touch pad itself of some other component?
A magician was driving down the road..then he turned into a drive way…Why don’t aliens eat clowns.Because they taste funny.What do you call a fish with no eyes?A fshTwo snowmen are standing in a field. One says to the other : “Funny, I smell carrots too”.What do you get when you cross an elephant and a rhino?el-if-i-no**Black UGG Bailey Button BootsChestnut UGG Bailey Button BootsChocolate UGG Bailey Button Boots**Two peanuts walk into a bar.One was a salted.Once upon a time there were two muffins in the microwave. Suddenly, on of the muffins says:"Man it’s hot in here!!!"The other muffin exclaims,“Look a talking muffin!!!”
If your model has one of those cheap, easily worn/broken plastic door latch switches - I’d check that out. If the switch is defective or broken, it would prevent the control pad from activating.
I went through 4 control panels in 1 year. The last bad one they didn’t take and left it behind. I noticed I could peel the top of the panel back from the right top corner exposing the contacts for the pause and the on buttons. Both had a milky tarnish from obvious water contact even though the panel was a couple months old. What quality control and engineering that is! Any way you can wipe clean with a contact cleaner, try and seal the corners with some rtv to prevent future water contact.
[SIZE=3][COLOR=#000000][FONT=Times New Roman] [/FONT][/COLOR][/SIZE]
