Maytag topload washer slow to fill
The washer fills very slowly (over two hours to fill with cold water) Please diagnose problem and suggest the correct part to solve the problem.
A couple of questions
  1. If you do a wash cycle with the hot water option does it take a normal or excessive amount of time to fill up with the hot water?
  2. Have you unhooked the cold water line from the washer and checked for
a. a blockage in the cold water line from the faucet to the washer. Stick the washer end of the cold water line in the laundry tub and turn on the water to see if you have good flow.
b. Have you checked the place where the cold water line connects with the washer. There should be a screeen inside the water valve coming out of the washer, and sometimes this screen is clogged.
If hot water is coming in normally and there are no blockages on the cold water line, your most like problem is the solenoid valves that open and close to let water in. Here is the part for your machine.
Replacement parts for MAYTAG LAT2500AAE | AppliancePartsPros.com
Good luck and please post what you find
