Maytag some buttons don't work
once the heavy, normal, or light button(s) are pushed then the steam & heated dry buttons light and unit locks up and only the heavy, normal & light buttons will work. I’ve already disconnected the ribbon wire from controller and then powered unit back up & the drain motor did come on for 2 minutes. I don’t know what else to do until I find a repair manual for it. any suggestions?
Parts for Maytag MDB7709AWW2 Dishwasher - AppliancePartsPros.com
The tech sheet is too large to upload on this site so I has to use another site, see below
Download MDB7709.pdf
Un-click the " use our download manager" as this may install software on your computer t6hat you do not want and then download it using the gray button.
Does sound like a control board problem.
You could check the control panel/keyboard keys with a meter (see the tech sheet). If it checks out OK then I would replace the control board.
You may also want to try the following.
Connector Cleaning / Checking
Unplug the unit
Open it up
Clean the edge connector. Use electronics contact cleaner or isopropyl alcohol.
I noticed my heat dry key quit working last week..stayed on. Then last night I tried to turn my DW on and nothing. The start button is dead..get a few buttons to light up but no start. Could this be a bad touch pad control or should I go with the control board?
I did unplug the control panel from the board and plugged back in …drain pump worked for about a minute or so…then everything shut down again.
