Maytag Self Clean Oven Not Working
Everything worked fine until i had to replace the bake element , which
i did and it bakes fine , when i start the selfclean program the door locks
just fine, the uupper element broil come on and after about 30 minutes the
display goes off no clock nothing, the bake element never goes on, after about 1/2 hour the clock comes back on and i can open the door,
the control pane is only 2 years old the old one had to be replaced due to
cracks in the numbers which did not allow the to function to set clock or
temp. any suggestions.Ron
[quote=madbchgalry@aol.com;811633]Everything worked fine until i had to replace the bake element , which
temp. any suggestions. Ron[/quote]
Ron, Before you replace the ERC
AP6005087
You’ll want to check and ensure the cooling fan
AP6010883
is energized at the start of the self clean cycle, and cooling the area between the cooktop and the oven, behind the control panel. If it’s not, the hi limit switch
AP6010676
Under the cooktop will “open” and remove power to the ERC until the area cools down and the switch “closes”. The broil element only is activated for the first 40 minutes of the self clean cycle, after the 40 minutes, the bake element cycles on and off to maintain the high temperature to clean the oven. If the cooling fan and hi limit switch and wiring check OK, you’ll need to replace the ERC.
