maytag resistor r11 value
Can someone tell me the values of the r11 resistor & the q6 triac for the maytag mah 400 washing machine. These components show as burnt on the control board and are the usual suspects in the “no spin” malfunction.
thanks
I don’t have specs on their values, but they burn out pretty regularly so if you search the web you can find replacements at a very low cost.
Also, change out the wax motors or the board will just burn out again.
