I too have an old Maytag MDB6601AWW
all the lights/buttons on my keypad work with the exception of
the center (3)
autocelan start/stop delay
I’ve read thru a bunch of these forums…
but I can’t find any info on how to get the machine to give me an error code…
Is it my circuit board?
Is there just something simple that is not “locking” the machine so it can start?
HELP would be appreciated!
tks
joel
It is for an AWB but should be the same or close to a AWW
Check the switch outputs at the ribbon cable with a meter.
Looks like track 10 is common to those 3 switches.
Connector Cleaning / Checking
Unplug the unit
Open it up
Clean the edge connector. Use electronics contact cleaner or isopropyl alcohol.
If everything checks OK then odds are that it is a control board problem.
