Maytag quiet series 100
this dishwasher won’t start. A couple of months ago it wouldn’t start, i took the inside panel off and put it back on, and it worked fine for a month or so. Nowit’s doing the same thing. i replaced the door handle assembly. still won’t run. Do you thin k it is the push buttoon/ control panel? I would appreciate a few suggestions before I drop another $60.
Any suggestions would be much appreciated.
rebel1222
Replacement parts for MAYTAG MDBH950AWS Dishwasher - Undercounter | AppliancePartsPros.com
Here is the tech sheet
http://www.servicematters.com/maytag_library/docs/16023222.pdf
Here is a manual
http://www.servicematters.com/maytag_library/docs/16021814.pdf
I am assuming the unit is totally dead.
Sounds like you have a bad connection somewhere.
First remove power from the unit and check that the wire nuts connecting power to it are OK.
Next remove the doors inner panel and check that the wires from the control going under the unit are OK.
Check that the door switches are closing with a meter and that power is getting to the control board.
if OK.
Try the following cleaning procedure.
Check the control panel (keypad) with a meter. See the tech sheet.
If OK
Odds are the control board is shot.
Connector Cleaning / Checking
Unplug the unit
Open it up
Clean the edge connector.
