Maytag portable dishwasher mdc4650aww
the coupling leaks but sometimes does work. Is there anyway to repair this?
And if I need a new coupler and hose ass., exactly how do I access the assembly? Do I take off the top board?
Parts for Maytag MDC4650AWW Dishwasher - AppliancePartsPros.com
The coupler/hose is item 15 in section 01. Click on it’s picture for more info on it.
Also check out the faucet adapter (item 10) to be sure it is the same as yours.
[COLOR=“Blue”]Is there anyway to repair this?[/COLOR]
There are not any internal parts available for the coupler. You have to replace the entire assembly.
Coupler/Hose Removal
  1. Disconnect power to the machine.
  2. Remove Wood Top, see “Wood Top” removal
    procedure.
  3. Remove Foil Bottom, see “Foil Bottom” removal
    procedure.
  4. Disconnect power cord from the terminal box. I am not sure that this is absolutely necessary.
    Disconnect the fill hose from the water valve and the
    drain hose from the drain pump.
  5. Remove the wire tie securing the drain and fill hoses
    to a rib on the tub.
Wood Top Removal
  2. Remove the 2 screws securing the top to the
    mounting flanges positioned under the top in front.
  3. Carefully slide top forward to disengage spacer
    washers from slots in the rear of the cabinet flanges.
Foil Bottom Removal
Partial removal of Foil Bottom will allow access.
  2. Lay down a protective pad. Carefully tilt the unit on its
    back, onto the protective pad. Remove 2 fasteners on the sides.
  3. Partially remove the Foil Bottom by folding down.
Thank you so much. I really appreciate the help because it is not obvious how to do it. matt
