Maytag performa washer
i just got a decent washer, model#pavt244aww, maytag performa washer and i hooked it up yesterday and started running it, and after it filled up with water it started making a loud buzzing noise, i then put it on the spin cycle to see if i could get the water to drain, still no luck, it was still making the loud buzzing noise,and would not spin or go into any cycle, all it will do is fill up with water, i am wondering if it might be the motor in it? i really dont think its the water pump, but their is always the possibility…. i need help!!!someone plz help me
Tilt the washer back and remove the belt. Check if the pump is moving freely in both directions. Turn the washer On and see how the motor works. Post the results.
Here are the breakdown diagrams and Replacement parts for MAYTAG PAVT244AWW | AppliancePartsPros.com
well gene i tilted the washer back and took the belt off the motor spins but, im assuming its the water pump, its not doing anything at all, then i put the belt back on and left it leaning back and the horrible noise was coming from the pump towards the back of the washer, do u think i need a new pump?
The pump is the culprit. No doubt about it. This is one of the most common problems with those washers. Maytag had redesigned the pump and it should last longer now.
