Maytag Performa washer does not spin
We have a Maytag Performa belt-driven washer model LAT25200AEE that worked normally up until recently. The washer fills and agitates properly,; the pump works normally to drain the machine, and the motor seems to work properly. However, the basket does not spin when the washer goes into the spin cycle. A squealing sound develops and there is a smell like burning rubber. I assume that the smell is due to the drive belt slipping on the non-moving pulley as the motor responds to the call to go into the spin cycle.
Does anyone have a diagnosis of the problem? Many thanks for your interest.
[quote=ret2002;254334]We have a Maytag Performa belt-driven washer model LAT25200AEE that worked normally up until recently. The washer fills and agitates properly,; the pump works normally to drain the machine, and the motor seems to work properly. However, the basket does not spin when the washer goes into the spin cycle. A squealing sound develops and there is a smell like burning rubber. I assume that the smell is due to the drive belt slipping on the non-moving pulley as the motor responds to the call to go into the spin cycle.
Does anyone have a diagnosis of the problem? Many thanks for your interest.[/quote]
Correction: The model number of our Maytag Performa washer is LST2500AAE. Sorry for the error in the original post.
Here I go again: The model number is LAT2500AAE.
