my maytag oven comes on and starts to heat and then makes some clicking noises and then shuts off. No error code pops up on the control panel. How can I fix this?
Hi.
Most likely the problem is bad relay board
It’s inside the control panel, next to the clock.
Here are the breakdown diagrams and Replacement parts for Maytag CRE805 RANGE- S/C F/S ELE | AppliancePartsPros.com
Thank you. Post the results.
Simon.
