I have a maytag oven that does not keep the correct temperature. Temperature is set on control board and is lower in oven.Used two thermometers inside of the oven to compare temperatures. Both elements do work
[quote=mikedupre;607297]I have a maytag oven that does not keep the correct temperature. Temperature is set on control board and is lower in oven.Used two thermometers inside of the oven to compare temperatures. Both elements do work[/quote]![]()
