I can’t clean my ovens. When I press “clean” for either oven (this model has two ovens) nothing happens except two beeps. Can I fix this?
Parts for Maytag MER6875ACW Range - AppliancePartsPros.com
Try getting into the diagnostics.
It may help pinpoint the problem.
If everything comes up normal then odds are that the control board is the culprit.
Have you tried shutting power off to the unit for a few minutes to see if it will self reset?
MER6875.pdf (1.3 MB)
