I just bought from a friend her Maytag Precision Touch Control 700 Electric Smoothtop (model # MER5775QCF).
The smoothtop surface is working 100%, but the oven doesn’t respond to any heating command at all (I knew that when I purchased the oven).
So, my question is, do you think that my control board has to be replaced? If yes, how much and where can I buy it from the web? Also, how can I check to be sure that the 2 elements are not the problem (I have a multimeter at home, but I believe it is mostly unprobable that the 2 elements are broken in the same time…).
