Maytag Not Filling
Brand:
Model Number: MHW6000W1
Main Symptom: Will not fill
Start cycle, tries to fill. I hear the clicking and when I rinse or fill shows on the display, water does not flow, it tries but no water flows through valve. I do not have any kinks in hose, water pressure is great, door is fully closed & locked, and I just replaced the Washer inlet valve. Still will not fill. Before I replaced the inlet valve, I was only getting the F08 error. Not will the new inlet valve I get the F08 & E02 error.
Error Code (if any): F08 & E02
Parts or tests already tried: Washer Inlet Valve P/N: WPW10289387
Photos / video link: Dropbox
Missing a digit. Please recheck.
I found these:
F02 Overflow condition Unplug the washer and, if the washer is overfilled, check the water valve assembly for proper water shut-off. If the water valve assembly is defective, replace it. If the washer is empty when this error code appears, replace the water level pressure switch Water valve assembly, water level pressure switch
Might learn more with the complete model#. Best of luck with your repair.
jeff sr.
The error F8E2 is going to indicate that the dispenser motor is unable to reach the desired position. Usually, this is a failure in the position switch of the motor. The less likely cause would be with the CCU control.
Dispenser motor assembly- WPW10352973 Dispenser Actuator | Genuine Whirlpool OEM In Stock
CCU control- W10427972 Electronic Control Board | Genuine Whirlpool OEM In Stock
Thanks William.
The Dispenser Actuator is 120VAC and is working great.
I put a multimeter on the Intake valve which is brand new and I am only getting 27VAC from the Control Board and I should be getting 120VAC.
Long story short, I ordered a new Electronic Control Board.
Thank you for your input, it was very helpful.
-Rich
